12-18-2008 11:31 PM
If I use the the Event "Array" Mouse Down, Is there any way to know which element in the array was clicked???
Thanks.
Solved! Go to Solution.
12-19-2008 12:00 AM
In the LAVA Code repository there is a piece of code that check that for you, it takes the current index position into account, size of the eleements.
Unfortunatly the website is currently down. Let me check later.
Ton
12-19-2008 12:52 AM
You can do something similar to what I did in the toc tac toe entry as described here. Let me know of you have any questions.
(your problem is simpler, because you only have one dimension :))
12-19-2008 09:23 AM
Here's a link to the file I described.
Ton
12-19-2008 10:37 AM
