Event Node is empty
I have an event structure that was originally fine. However I had to change some things so I ended up deleting some clusters and creating and rewrining. It has all been rewired the same just a new cluster, but it still says the Event Node is empty and that the structure contains bad wiring or is unwired. Any possible reasons I could still be getting this error?
(3,077 Views)
Can you please show the Event structure and the error window. I possible attach the VI
(3,074 Views)
I just realized you can't see the cluster. It's just a reference to it. And all the other structures are similar just refer to different clusters.
(3,070 Views)
Accepted by topic author amling44
It clearly shows that the event associated with that Event case is not available. I believe you might have deleted the control, please go to Edit Event Structure and config again.
(3,062 Views)
Here's your answer.
If you rename the cluster, the event will take on the new name.  If you delete the cluster, there's no longer a control for it to be associated with.  It removes the event entirely and lets you figure out how to fix it.  Right-click the border of the event structure and choose "Edit Events Handled by This Case" and update it to use the new cluster.
(3,057 Views)
