07-28-2015 01:17 PM
Hi everyone,
I'm using E/IP read tag blocks (type REAL) in my Labview 2014 vi. I'm attempting to take the data from these and bundle them into a cluster, where the inputs for them are doubles. So far, I haven't found a conversion that satisfies Labview.
Any thoughts and advice would be greatly appreciated.
Thank you,
Nick
07-28-2015 01:41 PM
I'm not understanding your issue. You can't figure out how to use Bundle or Bundle By Name to create a cluster?
07-28-2015 02:05 PM
I've got a bundle block with some double slots to cram data in. The data type coming from my EthernetIP tag read is a real type.
Thinking about it some more, I believe I've hit this kind of issue. I'm forgetting that the data that comes out of a read tag isn't just a variable. It's an array consisting of an index and the data I want. That's probably the issue. Take a look at the bottom middle of this block diagram.
07-28-2015 02:11 PM
Yep, you are reading an array of values. And array cannot go directly into a scaler. You probably just need to use Index Array since you are only reading a single sample.
