EtherNet/ IP basics
I'm looking for some basic info on using EtherNet IP conmms with LabView. In the past I've using RS-Linx and LabView datasocket to communicate with a PLC. Can I use a similar approach with EtherNet IP? Do I need the LabVIEW Driver for EtherNet/IP, Driver for EtherNet/IP and RS Linx or just RS Linx?
Simon
(4,494 Views)
You just need the LabVIEW Ethernet/IP driver.  And there are some decent examples if you look for them (Help->Find Examples).
GCentral
(4,464 Views)
OK thanks. That's what I needed to know.
(4,447 Views)
