Errors with NI DAQmx after leaving computer for an extended period of time
I am collecting data from two thermocouples using the DAQ assistant and have been getting Error-201003 after walking away from the computer for extended periods of time. If I restart the computer, it works perfectly fine. It mentions that it could be because the USB DAQ board was unplugged/turned off, however that is not the case. As I am new to LabVIEW, how do I make the .vi so that I do not get this error? Is there a specific way to save the code? Having to restart the computer each time is not going to be acceptable. I have attached the code. Thank you for any help!
(1,996 Views)
WIndows often turn off power to USB ports. You might want to check that.
(1,990 Views)
