06-10-2015 12:52 PM
06-10-2015 02:16 PM - edited 06-10-2015 02:16 PM
Is there a reason for such a high sampling rate when a sampling rate two orders of magnitude lower would suffice? (i.e., Hundreds of samples per second and not tens of thousands?)
06-10-2015 02:19 PM
Yeah, you are taking way too many samples. Per Nyquist, in order to see a 70Hz signal, you need to sample at least 140S/s. I like to use more like 10x instead of 2. So change your sample rate to more like 1kS/s. This will reduce the amount of memory you are using by 90x.
06-10-2015 02:23 PM
Maybe catching transients at the kHz level, come to think of it?
06-10-2015 02:36 PM
Many thanks for your replies, actually with lower sampling rate, I can'i obtaon good result, So I have to increase the sampling rate, because only in this case my results are in the acceptable range.
06-10-2015 02:38 PM
We are thinking of buying a new PC with 32Gb RAM and a good processor.but I thought, maybe it wouldn't a good solution. As you that type of PCs are expensive.
06-10-2015 02:38 PM
That's impossbile. There's something wrong with the way you are acquiring the signal if that is the case.
06-10-2015 02:41 PM
So, what are you suggesting? I can perform the experiment without any problems, but sometimes I face this error 😞
After the experiment, when I import those matrices to MATLAB for process, it takes 5-6 minutes time. So I'm thinking of RAM
06-10-2015 02:45 PM - edited 06-10-2015 02:48 PM
I think you have to think about why you can't capture a good signal using the Niquist standard? (Sampling rate twice the frequency.) Or even 3x or 4x (280 S/s)?
Edit - or even 10x as was suggested.
Are you actually trying to capture something out of band?
06-10-2015 02:48 PM
It's sweep, the frequency changes from 40-70, so you mean I adjust the sampling rate to 140.?
Okay, I'm going to try it, though I've tried 1000 before.
