11-05-2014 02:52 PM
I'm trying to simulate my FPGA VIs using desktop execution node. I get error(as in attachment) every time i select any fpga vi. What's wrong?
Solved! Go to Solution.
11-06-2014 01:28 PM
The error seems to be associated with using a variant data type incorrectly. Please refer to the following document when working with these data types: (http://www.ni.com/white-paper/4998/en). A variant may not be the best structure to use in FPGA code because it is resoruce intensive. What are you trying to achieve by using this data type? Best of luck!
11-06-2014 03:13 PM
Thaks for your answer, Roel
I've never used variant data type in my FPGA VIs. For example, I attached the simplest VI i tried to select in Destktop Execution Node Configure Dialog but got the same error.
As I understood the error associated with nifpgaDEN_Dialog_DrawTreeFromTreeInfo.vi that is part of Desktop Execution Node software. So maybe I should reinstall something?
Additionly, after I pressed Continue on Error Dialog, DEN Configure Dialog becomes inactive - see second attachment - five buttons are pressed but no reaction is present.
I hoped FPGA DEN would help me to debug my FPGA subVIs, but now I don't know what to do.
11-07-2014 10:57 AM
Hi kostyuk.a
Can you let me know what OS you are using (32 or 64 bit also), which version of LabVIEW FPGA you are using, and which version of the RIO driver? This may be a bug depending on those factors.
11-07-2014 04:13 PM
i got same results on 3 different PCs:
1. Windows XP + LabVIEW 2014(32b)
2. Windows 8.1(64b) + LabVIEW 2014(32 b)
3. Windows 7 (64 b) + LabVIEW 2014(32 b)
LabVIEW FPGA 2014
NI-RIO 14.0.1
11-10-2014 03:53 PM
Thanks for the info! If this is occuring on multiple computers, it very well may be a bug. I just did a quick search of our bug reports and did not find anything regarding what you're seeing. I will try to reproduce the issue on my end.
I'd also like to know what FPGA target you are trying this for? Could you attach screenshots of your project?
11-11-2014 02:34 AM
Hello, Daniel
We use PXIe-7966R, screenshot is in attachment
Additionally I,ve attached screenshots of dialogs defore and after selecting a VI
11-11-2014 02:48 PM
Hi kostyuk.a,
Does this same error occur for any VI you select, or just a specfic set of VIs?
11-12-2014 02:34 PM
Hi Roel,
The same error occurs for every VI from list of FPGA Targets VIs from My project
11-13-2014 01:38 PM
Hi kostyuk.a
Thank you for all of the information you have provided us. It seems like a bug that I will report to our software developers, and work with them to see if there is a workaround.
