12-26-2013 01:35 AM
I designed VI successfully...there is no error....there is no broken symbol on VI ...so Every thing is fine.
But when i went to save it ......i received one error i.e.VI failed to compile....also observation broken symbol on VI.....
But i could not find the reason for it.
Should guide me to resolve it...or what will be the reason....
I have one concern which may be reason.....Suppose i have taken one Indicator terminal out from SubVI ..but i have not used it....i keep it free...not used
...do you feel it could be reason or anything else ?
Thanks in Advance.
12-26-2013 01:47 AM
What is your LabVIEW version? Can you attach the VI?
What does it tell you if you press the broken run arrow?
12-26-2013 03:57 AM
Thanks in Advance.
Is that a normal VI on windows or you trying to use any target? I never encountered the compile error while working within a VI on windows.
12-26-2013 04:33 AM
