01-13-2014 02:28 PM
The code below works when I deploy libraries containing most network shared variables. However, If one of the shared variables is bound to an I\O variable the code fails to deploy and returns the generic error -2147467259.
Is it possible to dynamically deploy I\O bound shared variables or is it only possible to do this Manually using the project tree?
01-14-2014 05:57 PM
Can you post a screen shot of the error pop up?
Are you also deploying to your remote target?
What's the hardware acquiring/generating the data for the variables?
