10-06-2006 04:06 PM
Hello
I got this problem when I send Email using SMTP. I am able to send the Message and the multiple attachments. But the recipient gets the email with this message
“This message uses a character set that is not supported by the Internet Service. To view the original message content, open the attached message. If the text doesn't display correctly, save the attachment to disk, and then open it using a viewer that can display the original character set.”
In the attachment that recipient receive is only one file and in that file there are all attached files data along with other information such as:
“Received: from XYZ with SMTP (Microsoft Exchange Internet Mail Service Version 5.5.2653.13)
id T5KY41PZ; Fri, 6 Oct 2006 16:46:22 -0400
MIME-Version: 1.0
Content-Type: multipart/mixed; boundary="LabVIEW_SMTP_MIME_Boundary"
Content-Transfer-Encoding: 7bit
To: xyz.com
Subject: ErrorLogs Files
Date: Fri, 06 Oct 2006 16:46:20 -0400
--LabVIEW_SMTP_MIME_Boundary
Content-Type: text/plain; charset="%s"
Content-Transfer-Encoding: quoted-printable “
I want to see all attached files separately
If any one know the solution please guide me to solve this problem. I send the link of the library I used for this application and I use “SMTP Send Multiple Attachments.vi” to send multiple attachments.
Thank you,
Amit
10-09-2006 09:04 AM
10-09-2006 11:05 AM
Hello Nathan
Yes, sending an email without attachments work good as well a single attachment. But when I use Multiple attachment the problem comes. I have not tried sending it to different email servers with ant virus disable. That is good point. I have yahoo account but I do not know the email server name. If you know please let me know so I can test it.
Thanks for you help,
Nathan
10-10-2006 04:33 PM
10-10-2006 04:39 PM
Hello Andy
Let me try the SMTP library instead of the ones on the palette. I try what Nathan suggested using the SMTP but same problem.
Thank you
10-11-2006 10:17 AM - edited 10-11-2006 10:17 AM
Thank you for sharing your knowledge Nathan and Andy.
I had two location for SMTP library one was old and other was new in the vi.llb folder. The New SMTP library worked.
It solved problem I was getting.
Thank you
Message Edited by amittpatel@yahoo.com on 10-11-2006 11:18 AM
