01-12-2007 10:00 AM
Does anyboy know the reason for this message?
Thanks.
01-15-2007 02:34 AM
Can you pls try the things that are said in this KB and let us know if u ar in any of those situations?
http://digital.ni.com/public.nsf/websearch/705C2ECA081F3C7986256C0F00559B02?OpenDocument
01-16-2007 04:26 AM
01-16-2007 11:27 AM
Can u check this links to find a possible solution?
http://forums.ni.com/ni/board/message?board.id=110&message.id=3817&requireLogin=False
http://forums.ni.com/ni/board/message?board.id=170&message.id=178723&requireLogin=False
Try also:
force recompile his program, look for VIs with identical names, and copy the block diagram to a blank VI
Let me know if that works...
01-19-2007 05:35 AM
Something was wrong in LabVIEW but I don't know what. I've installed again LabVIEW in the computer and now I can create executable files without any problems.
01-19-2007 05:54 AM
Ok...
good to know u solved the problem... It is always better to try almost everything before doing reinstallation or something like that, but nice u have everything working now!
