Error in reading a digital signal
I am trying to read a digital signal from NI USB 6215 from PFI0. But, When I run the VI, an error shows saying:
Error -200077 occurred at Property Node DAQmx Timing (arg 1) in DAQmx Timing (Burst Import Clock).vi:5840001->digital_cI.vi
Possible reason(s):
Requested value is not a supported value for this property. The property value may be invalid because it conflicts with another property.
Property: SampTimingType
Requested Value: Burst Handshake
Possible Values: On Demand
Please suggest any reasons. I attached the error and the VI.
(3,006 Views)
Accepted by topic author Santhosh_kth
Hello Santhosh_kth,
the digital lines of the USB 6215 are static so only software timing can be used. The DAQmx timing vi must be removed.
Page 7 in the USB 6215 specifications
best regards
Alexander
(2,965 Views)
Thank you. I understood the problem. But, if I want to read the digital signal in a 'continuous' mode using a sample clock, what type digital lines are required?
Thanks again.
(2,950 Views)
Hello Santhosh_kth,
detail explanation for your device:
Correlated DIO with USB M Series DAQ Device
What Options Do I Have for Hardware-Timed Digital I/O on My M Series DAQ Device?
You have to use a different hardware like a x-series card or a external powered usb device from the m-series.
best regards
Alexander
(2,943 Views)
