07-26-2005 05:22 AM
07-26-2005 05:31 AM
Hello
I have attached a wrong Vi file in the earlier pls find the file attached .
07-27-2005 09:14 PM
I am not sure I understand your problem. It sounds like you are able to run the VI with no problems. Do you get an error when trying to build an executable or when actually running the built executable? Also, any more information on the error you receive (the text of the error message, error message number, etc…) will help. Thanks!
Chris J
07-27-2005 09:34 PM
07-27-2005 09:36 PM
07-28-2005 12:48 AM
07-28-2005 04:53 AM - edited 07-28-2005 04:53 AM
Message Edited by anusree on 07-28-2005 04:55 AM
07-28-2005 08:24 PM
There are three problems that you need to address immediately.
First, you generate the path to the same file in four different places. Get the path one time and wire it everyplace it should go.
07-29-2005 01:10 AM
Hello Mike,
Thanks for suggestion,
when I do as first suggestion the file missing error pops up in the labview run itself, The error number is 7
I have straighten the wiring and posted sorry I could not understand the third suggestion, This is the change which has to be made while creating the set up file
07-29-2005 01:12 AM
