NI Home
Cart Cart | Help
You are here:
Reply
Member
LW42
Accepted Solution
Error code database is password protective without putting a password!!!
I am using LabVIEW 8.6.1. Everyitme I use the "find and replace" option selected from the edit menu I get the notification "error Code database. vi is password protected...", please see the full message on the attached screen capture. I have never put a password. Can somebody suggest why this is happening and advise how to stop it. The skip option works however I don't want this inconvenience.
Thank you in advace
Proven Zealot
MikeS81
Re: Error code database is password protective without putting a password!!!
Hi thorfano,
is this  subvi from you? Maybe it's from NI and they use sometimes a password.
Mike
Member
LW42
Hello Mike. Thank's for your response. I am not sure if I gave you understand what I am doing. In a vi that I did by myself I select "find and replace"choice (from the "edit"of labVIEW menu) and looking for a text that exists in my vi. e.g SP O2%. Then the message sent before appears. What I am doing has nothing to do with the "error code database vi" at least I can't see the correlation.
Thank you
Proven Zealot
Hi thorfano,
it's definetely a vi from NI. It's the database for all those error messages and hidden somewhere in the "general error handler" vi.
You probably used this (or any other related function) in your vi hierarchy and so the search also tries to access this function when searching for text...
CLAD, using 2009SP1 + LV2011SP1 on WinXP+Win7+cRIO
Kudos are welcome :smileywink:
Member
LW42
Thanks Gerdw for your reply. Thus, you say its normal to get this message and I can't do nothing (rather than select "skip") to prevent message apperance. Am I right?
Thanks in advance
Trusted Enthusiast
rolfk
If you only want to search in your current VI then select that as scope. If you want to search in all VIs loaded into a particular instance I do not think you can avoid that stupid dialog currently.
Rolf Kalbermatter
Rolf Kalbermatter
CIT Engineering Netherlands
a division of Test & Measurement Solutions
LabVIEW Champion
Trusted Enthusiast
TCPlomp
Rolf Kalbermatter
Isn't there a 'Ignore VI.lib' Setting for that dialog as well?
That should help.
Ton
My LabVIEW Ideas
Trusted Enthusiast
rolfk
Ahhh yes, that seems to be a feature since LabVIEW 8.0.
Rolf Kalbermatter
Rolf Kalbermatter
LabVIEW Champion
Member
LW42
Good morning,
Thank you all for the help, the choice "ignore vis in vi.lib" is ticked (selected) and I wonder why it doesn't work. I checked and found that the "error code database vi"is inside the vi lib as expected. I also checked if somehow the "error code database vi" is present in another location in my computer, nothing found.
Best regards
Active Participant
waldemar.hersacher
thorfano,
add a Kudos and perhaps a comment to this LabVIEW Idea.
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
