04-03-2015 01:16 AM
I'm planning on using a MCC DAQ for measuring frequency through an analog port. My input is in the form of pulses with varying amplitude, and I need to be able to measure their frequency. I am very new to this and don't really know what the problem really is.
I have tried two methods and am facing different problems with them. Please help.
To simulate the signal, I'm using InstaCal (virtual board from Measurement computing) to generate a sine wave of amplitude 5V. I don't know what frequency the signal is at.
I made a sample program but it keeps showing the error:
Error -20315 occurred at Timing and Transition Measurements2->testflow.vi
" (waveform index 0 of 1)
Analysis: The waveform dt parameter is <= 0.
I have attached the code below (capture.jpg).
I also used the timing and transition VI with the sampling clock and start VIs in a separate code and in that case it doesn't work with a sine wave at all. (displays the message: Error -20312 occurred at Timing and Transition Measurements->UI_2.vi
The input waveform size is zero).
For a square wave, it keeps showing some the frequency at "2500", and after 2-3 times of running, throws up the same error (20312) with "2147483647" in the same frequency display.
I haven't put it in a while loop to figure out what happens when you run it once. If I do need to put it in a while loop, which elements should I put in the loop?
Thanks!
04-03-2015 07:11 AM
04-03-2015 09:55 AM - edited 04-03-2015 09:55 AM
Noise: My application is not very sensitive to noise, I need to measure RPM (0-2500):
Frequency: The sensor output will be in the range of 0-2500 pulses/sec
Amplitude: Will be in the range of 0-4V, proportional to RPM. Voltage is induced through a mag pickup with a reference of 1.5V at 1000 RPM. I can use a threshold of 0.15V (100 RPM) for low-high cutoff.
Noise, I am not sure, as far as I know the sensor is pretty accurate (<0.02% at all frequencies) which is sufficient for my application.
I'll be using a MCC DAQ with a capacity of 33-4000 S/sec in occasional scan (software paced) mode and 250 kS/sec in continuous scan (hardware paced) mode. I don't know what I need to do in Labview to distinguish between the two modes but I would like to use the hardware paced mode.
Could you suggest the best possible method for my application?
Do I need to use the sampling clock/start VI with the Timing-Transition express VI?
Which sampling rate should work the best?
If measuring the times between points is the best way, do I need to use a different input or an analog input will do? Also, which VI should I use for this purpose?
I know I'm directly asking for the solution, but I need to get the job done quickly.
Again, thanks for your help!
