01-18-2013 08:09 AM
I'm getting a R6034 error when I attempt to load a 3rd-party DLL into a CallLibraryFunctionNode:
I figure it has to do with missing dependencies, but I'm having problems getting everything in order. Using 'Dependency Walker', it lists 'ieshims.dll' and 'wer.dll' as missing. When I add those (from download sites), new dependcies are formed the process repeats.
The work was done on a Windows XP w/SP3 (virtual) machine. You can download a zip of the DLL in question as well as the other DLLs contained in the same folder here (it was too large to attach). The DLL in question is 'TndRtrApi.dll'. If someone with more experience in solving these problems could take a look, I'd appreciate it. Thanks.
-Joe
01-18-2013 10:11 AM
Sounds like you need to be in conversation with the 3rd party that wrote the DLL and findout what dependencies it has and where they need to be located.
Mike...
01-18-2013 12:08 PM
You have a mismatch in dependant DLLs, this problem is not LabView related.
If some of your libraries require manifest files and you do not have them, this might be causing the problem. Look at MSDN for the problem description.
