08-29-2014 08:01 AM - edited 08-29-2014 08:04 AM
I suppose you could use a case statement with a case for each of your error codes and use the error ring to generate a corresponding error code. That's like what you want to do. Use the error ring to select the error you want to generate.
08-29-2014 08:21 AM
The problem with that is that it is extremely difficult to cover all errors. That's why I recommended the Create Error From Error Code and then use the General Error Handler to do the actual looking up of the error code for you.
08-30-2014 01:31 PM
I see. I was thinking that he just needed a few error codes - but your solution is much more scalable.
09-02-2014 03:43 AM
Hey ph1,
i found something in our support portal, which might help you with your problem. I attach the document.
I hope that will help you with your problem.
Best regards
Dominik
09-02-2014 03:48 AM - edited 09-02-2014 03:49 AM
Hi Dominik,
oh, those were the days! 😄
1997 edition of LabVIEW error codes. Wow! (I guess the changes are rather small in the last 17 years.)
Did I mention the LabVIEW help before? Something like the list of VISA error codes?
09-02-2014 10:21 AM
Hello Dominik,
I have found this document, too, some times ago but where "discourages" by it's age.
EPH
09-02-2014 10:24 AM
Hello GerdW,
after an intensive search in the help (I don't now, why it is so confusing) I was able to find the VISA-Error-codes there. This works fine. To my luck I only need the VISA-codes and not all the others...
EPH
