08-31-2016 02:40 PM
Hey all. When I save a file as a .vi or a .exe, it loads perfectly fine and runs using Labview 2015, 32-bit on my laptop. I have to open these files on a seperate computer to run my files on a test set up, and this computer has a 32 bit version of the runtime engine and drivers, and gives me an error message when I try to load my files. It tells me to check the version of Labview on the computer (on the second computer) but I know they are the same version. ANyone have any ideas on what I should do?
08-31-2016 02:43 PM
Can you be more specific on what the error says?
08-31-2016 02:48 PM
"The version of this file is not compatible with the version of Windows you're running. Check your computer's system information to see whether you need an x86 (32-bit) or x64(64-bit) version" I'm fairly certain that both computers have the 32 bit version.
08-31-2016 03:03 PM
