Error BFFA0011 from niScope Cal Measure RIS Distribution
Hello all.
I am attempting to write a program to calibrate a PXI-5112, which has gone relatively well until I attempt to verify the RIS distribution. The niScope Cal Measure RIS Distribution VI returns a 0xBFFA0011 error (-1074135023): Function or Method Not Supported. Considering that all the other niScope VIs (including calibration VIs) I've used so far have worked normally, I thought this was a little odd. Is the RIS VI no longer supported with the 5112?
Thank you in advance for your help!
Alex
(2,144 Views)
This is a known issue, and has been fixed, please see the following KB article:
http://digital.ni.com/public.nsf/allkb/6303A230DCD1524986257BE9006641C9?OpenDocument
Systems Engineer
SISU
(2,003 Views)
