08-25-2016 08:28 PM
Hello! im trying to find all result of a string, in the second column on a excel document, i find this example searching in the forum, but im getting error 97 on invoke node in method FindNext, can anybody help me with this?
08-25-2016 08:35 PM
In order for us to help you, you should supply us with useful information. A picture of your VI is not useful -- the VI, itself (that we can edit, try to run, inspect closely, etc.) would help. It would also help if you included an example Excel Workbook and a clear description of what you want to do -- we might be able to come up with another method for your (but we need to better understand what you need).
08-25-2016 08:44 PM
Thanks for answer, here is the vi, an example of the excel sheet, i need to find in excel file all result of Part10 (for example), and the vi returns me the row and column, where is each one of the results.
Victor Mora
08-26-2016 12:36 AM
Hope Attached File will help to extract Values of Specific Row
08-26-2016 04:55 AM
Victor,
Sometimes you need to Adopt the Solution based on the relative strengths of the Platforms. Based on the example Workbook you attached, the simplest, most robust, easiest to program, and definitely fastest method to find a specific item (Excel row is what I presume you want) is to use Excel as little as possible. I would approach this problem as follows:
I see you are using LabVIEW 2013. The easiest way to "hook" LabVIEW and Excel is to use the Report Generation Toolkit, an Add-on for LabVIEW 2013. Here's a LabVIEW 2016 snippet (if you have the RGT, you should be able to simply duplicate this code yourself for earlier LabVIEW Versions), and a partial view of the Results that you can compare with the Workbook you attached (they're the same ...).
08-26-2016 05:15 AM
08-26-2016 09:10 AM - edited 08-26-2016 09:17 AM
@iadalbash wrote:Thanks for answer, here is the vi, an example of the excel sheet, i need to find in excel file all result of Part10 (for example), and the vi returns me the row and column, where is each one of the results.
Victor Mora
Change the _Worksheet Range method input from A1 to A:A (to search the first column). At the end wire ArraySize -1 to the lenght input of the Array subset function (not to the index input, that will give the last array element).
EDIT: You get error 97 when there is no match to the string to find in the specified range, you could filter out this error and specify "no match found" in the resulting array.
Ben64
