Error 7 occurred at Copy in ABAPI Dist New VI Library.vi->ABAPI Dist Chk for Destinations.vi->ABAPI Copy Files and Apply Settings.vi->EBEP_Invoke_Build_Engine.vi->EBUIP_Build_Invoke.vi->EBUIP_Build_Invoke.vi.ProxyCaller
When I try to build executables in LabView 8.01 I get message:
Best Regards
(3,386 Views)
Do you get this message when building any executable or on a particular VI ?  You can force LabVIEW to recompile the entire VI hierarchy in your project with CTRL+SHIFT+Run Button.
Tunde.
(3,374 Views)
It'is OK. I solve my problem. I have some old vi's included from LabView 7.0.
Thanks for help
Best Regards
(3,365 Views)
I got the same error as I tried to build my application, the reason was the string I set for the 'Build specification name' property of my build.
I changed from '3DC - Dlog Data Compacter ' to '3DC' and it worked afterwards..quite strange behaviour..
(3,240 Views)
