08-05-2012 04:29 AM
I have face this error Error -64997 during generation intermediate file. I am using Spartan 3E starter kit. Plz tell me what I am do?
Solved! Go to Solution.
08-07-2012 12:22 PM
What version of LabVIEW, LabVIEW FPGA Module and Xilinx Compile Tools do you have installed?
-Nick-
08-07-2012 03:23 PM
i have installed
labview 2011.
labview FPGA Module 2011.
NI labview FPGA xillinx 12.4 SP 1 tool.
NI FPGA compile frame 2011.
NI labview 2011 SP 1 FPGA support for spartan 3e.
08-08-2012 11:42 AM
I believe that the problem lies in that the driver is support for LabVIEW 2011 SP1 while you have LabVIEW 2011 installed. Though they year release is the same, the service pack mark indicates that theses are separate releases.
There were problems with support for these boards and LabVIEW 2011, thus the driver has been fixed and released for 2011 SP1, do you have access to upgrade LabVIEW and the FPGA Module to 2011 SP1?
-Nick-
08-09-2012 08:25 AM
i do not have an access to upgrade LabVIEW and the FPGA Module to 2011 SP1. i am searching labview 2011 sp1(32 bit) or labview 2011 fpga module sp1 (32 bit) but i can not find out .can you give me the link?
2nd question for you
it possible you can give me LabVIEW 2010 FPGA Driver for Xilinx SPARTAN 3E .?
08-09-2012 01:29 PM
I am waiting for your reply
08-10-2012 10:56 AM
You can find the downloads for LabVIEW 2011 SP1 and LabVIEW FPGA Module 2011 SP1 at www.ni.com/donwloads
Then sort by Software » LabVIEW (for the development environement) and Software » LabVIEW Add Ons (for the FPGA module). Or you can search for any product you desire. If your serial number is not valid for these products then you will only have access to the software for a short trial period. I would recommend checking with the adminstrator of your software license to see which versions you have access to.
Knowledge Base Article titled "Where Can I Find the LabVIEW FPGA for Xilinx SPARTAN-3E XUP Driver?" has links at the bottom of the page which will take you to all the downloads we have available for the FPGA driver for Spartan 3E.
-Nick-
