06-05-2012 06:06 AM
I am compiling a LAbVIEW FPGA code for a IF-RIO FPGA.
The code is compiled on a remote PC and then ported to a controller mounted in the same NI chassis of the IF-RIO board (by manually transferringthe LabVIEW project files).
Unfortunately, when I try to run it, LabVIEW returns the error 61017 and says that I must recompile the code.
In the past I was able to perform this operation without any problem, but now I have to recompile the code. Notice that the controller is much slower than the remote PC and this is the reason why I do not compile the code directly on the controller.
Is it a bug? Or could I have written some FPGA code that is somewhat changing when I tranfer the files?
Thank you
Solved! Go to Solution.
06-05-2012 06:23 AM - edited 06-05-2012 06:25 AM
Hi tom,
also read this…
First workaround: In the FPGA-Open node select the compiled bitfile instead of the VI (or build specification).
06-08-2012 03:12 AM
Thank you GerdW, your workaround did the trick!
I have selected the compiled bitfile instead of the VI. The only problem is that I had to remove all the type definition controllers from the FPGA VI, since they were genereting an error.
