Hello all,
I'm a member of a 4 man team working on a superdroid 6 robot, and we are using the teleop example that is available through NI on the internet. We have been tweaking it, because we have always had some sort of error preventing its total execution. Our latest tweak was to try to swtich from a UDP to a TCP connection. We have done a highlight execution of our robot and host station VI's, and it seems the TCP connection is establishing correctly, but on our first TCP read on the RobotMain VI, we are receiving error 56, which states :
LabVIEW: The network operation exceeded the user-specified or system time limit.
We have messed around with wait times and nothing is seeming to help us avoid this error, which is causing more errors further in the program with the motor controllers (specifically, error 116). If anyone has worked with this code, or knows anything about setting up TCP connections and dealing with such errors, any help or input would be GREATLY appreciated!!
Thank you!
-Marcy
