Error 50202
Hi!!, I have to Acquire 32 Channels of data with sampling rate 10k, I am new to labview, therefore I'm using DAQmx express and Write to Measurement File , the error is generated in the latter, There would be some way to resolve this error?. I have to sample for several days but the maximum  that lasts is 5 minutes, I have to come to think that is the amount of data, since  I am Taking data every 0.0001 seconds, and each file generated by Excel, is filled in about 6 seconds, not exceed the maximun 16 bit, somehow mange to store other data than using this express pallete?
(2,992 Views)
Try TDM-files b write your own binary format file
(2,958 Views)
I am using this type , saved in TDMS file,  but I have a bunch of data and the file freezed
(2,942 Views)
The DAQ Assistant Express VI is fine for simple tasks, and not bad for beginners who want to "get started" in doing simple DAQ Acquisition/Control.  You are trying to save 32 channels of data at 10KHz, or a third of a million samples per second.  If your samples are 16-bit integers, that's a (continuous) data stream of about 700 KB/second, or 2.8 MB/sec if you are saving Dbls.  This is certainly doable, but you might want to exercise some control over the data-writing process to ensure that it can run concurrently (in parallel) with the Data Acquisition.
This is certainly possible, and may even be do-able within the DAQ Assistant (I don't use this Express VI, so I am less aware of its true limitations).  However, we need to actually see (and be able to manipulate) your code to better advise you.
Please post the VI (or VIs -- if there are more than three, compress the folder that contains them and attach the resulting .ZIP file).
(2,923 Views)
