11-14-2014 02:36 PM
I am using a Ni-6008 to run a thermal die and I am getting the error "Error -50103 occurred at DAQmx Start Task.vi:11". I have read other discussion boards and this seems to combe because I am using the DAQmx assistant that doesn't properly clear the resource when finsihed. I dug further and saw that it is related to a timing issues for the onboard clock. However, I can figure out how to resolve this problem.
I was thinking that I would create some loop that constantly monitors the inputs and occasionally poll the memory so I don't mess up the clock. That is a lot harder to do than is sounds. Can anyone take a look at my code and give me some tips/suggestions to clean up the DAQmx assistants.
Thanks in Advance
Cole
11-14-2014 03:01 PM
11-14-2014 05:11 PM
I ended up splitting my resource between the two input channels by using a single DAQ assistant and dividing down the data rate and number of samples. Works fine now.
Big pain in the butt though.
