Error 50103 - Parallel triggered and continuous acquisition
I am trying to acquire two different AI channels (NI PCI-6115).
- Channel AI0 = triggered acquisition
- Channel AI1 = continuous acquisition
I am getting error 50103? Any ideas why?
Thanks a lot and best regards,
Michael
(3,068 Views)
Okay, the problem seems to be the two tasks I have generated. I can configure both channels in one task. But then, how can I configure channel AI0 to be triggered and channel AI1 to be continuous?
Thanks a lot.
Michael
(3,052 Views)
The following idea ends in error -200428.
(3,036 Views)
Thanks a lot.
Michael
I really don't think you can.
A task is a single activity.  The trigger defines when the acquisition task starts.  You can't have one channel acquiring and another one not.
Just have the task acquire continuously and discard the data from the one channel if it hasn't met whatever you defined as the trigger conditions.
For you next message, reading the description seems pretty clear and pretty much the same explanation.  You configure logging for a task.  It does not allow you to configure logging on a channel.
(3,022 Views)
@RavensFan wrote:
Thanks a lot.
Michael
Hm, bad news. Are there any examples for hardware triggered loops available? Maybe the following would work. If a hardware trigger occures, a fixed number of samples out of the continuous acquisition is used for calculation. The continuous acquisition still goes on. After calculation, the loop waits for the next trigger event.
Requirements:
- Up to 8 channels with 2,5 MS/s each (NI PCI-6133)
Thanks a lot.
Michael
(3,004 Views)
Thank's to NI germany support I have found a working solution. More informations can be found here.
(2,925 Views)
