04-05-2015 06:08 AM
I am using the HTTP-tool to get the body text from a website.
After upgrading LV 2014 to SP1 I now receive:
Error 363507 occurred at LabVIEWHTTPClient.lvlib:GET.vi:390001
Possible reason(s):
LabVIEW: LabVIEW could not verify the authenticity of the server.
Complete call chain:
Test.vi
Before the upgrade this worked with no issues.
My code also works fine on another PC that does not have SP1 (but 2014).
I tried installing the Runtime-Engine 2014 SP1 on a new PC - this also fails with error Error 363507.
What is going on?
The website I access is a public one, freely available in any browser. So I should not need authentication.
Obviously something changed going to SP1.
04-05-2015 08:06 AM
04-05-2015 08:24 AM
Well from a cursory check most other sites work, but not this one.
Tried a few public sites http and https...
At the moment I can find no other sites that exibits this behavior...
The website:
https://www.politi.dk/da/servicemenu/forside/
Chrome displays the website fine.
Same with IE.
04-05-2015 08:54 AM
04-05-2015 09:06 AM
Hehe - well google translate still needs a bit for work - but all pages on this site exibits this...
04-05-2015 09:19 AM
04-05-2015 09:45 AM
So what has changed from SP1 and is there a work-around?
04-05-2015 09:58 AM
05-05-2015 09:48 AM
Dear all,
I have looked into this issue and I'm wondering if anyone can give an example of a site where this behavior appears?
The https://www.politi.dk/da/servicemenu/forside/ site generate the same error for both 2013 and 2014SP1.
The error may be related to the SSL/TLS certificate on the sites. Which means that one need to configure the security of the http client handle.
Regards
Lars
05-06-2015 10:31 AM
Thanks for the reply Lars,
It is a frustrating phenomenon as this behavior is only seen in SP1 versions of Labview.
I have not found any other sites where this behavior occurs, albeit I have not searched alot.
Do you have a way of setting up the security of the http client handle as a work-around?
BR.
