I am trying to insert a table from labview into and excel sheet for plotting. I used one of the standard templates in the examples to successfully run "New Report.vi", inserted my table with "Excel Easy Table.vi", and viewed it with "Excel Bring to Front.vi". I then created the plot I want from the inserted table, and saved the resulting workbook as a template. However when I tried to run my program again using my new template (so my excel plot would be updated with the new data) it gave error3008:
Labview error 3008
Automation Interface for the specified class cannot be obtained. Check if the automation refnum type is the correct class for this operation in Excel_Get_Range.vi->Excel_Insert_Table.vi->Append Numeric Table to Report.vi->Excel Easy Table (num).vi:1->MyInsertCells.vi
Can anyone help - is there some other way I should save the workbook I want to use as a template? or some other standard place it should be saved?
thanks
Fred Engel
