Error -2318 occurred at Integrator.vi -> The dimension of the parameter vectors of this function do not match
I want to integrate each element of a 1D array (in a Control&Simulation Loop).
With the Integrator.Vi i get the following error:
The input (L*y) is a 1D array with a 1x78 structure. I want to have each element integrated for his own so that i also get a 1x78 structure as result.
Is this possible with this vi? Or has anyone a suggestion how to solve this problem?
I have also tried it with the numeric integration.vi but this gains only a single value (result).
Message 1 of 13
(4,174 Views)
can you upload your VI?
swirl
Message 2 of 13
(4,135 Views)
Unfortunately i am currently not in the office. I will upload the vi on monday.
Message 3 of 13
(4,123 Views)
I think i solved the problem.
I set the polymorpfic instance of the integrator.vi to vector and wired an initial condition with 78 zeros to the integrator.vi
Now it seems to work.
Message 5 of 13
(4,064 Views)
I am facing the same issue can you please help me for the same.
I am trying to implement the simulation model to labview.
Please suggest.
I have attached the vi and screenshot of simulink model.
Message 6 of 13
(3,474 Views)
I am facing the same problem.
Can you please help me to solve this.
I am uploading my vi as well.
Message 7 of 13
(3,093 Views)
Hi
can you help me out to solve this error. I am uploading my vi also.
Message 8 of 13
(3,074 Views)
Hi
Can you please help me out to solve this error. I am attaching my vi also.
Message 9 of 13
(3,072 Views)
   Can you help me out to solve this error. I have attached my vi also.
Message 10 of 13
(3,071 Views)
