Error -224606 Possible reason Internal Software Error occurred in MIO software. Please contact National Instruments Support.
It's been a long time since I've done a post.  The top posters seem to have changed.
We have some LabVIEW (2014) connected to an NI USB6001 running on a laptop in a zero degree celcius cool store.
The software stops and the error is:
Should I be ringing NI?  I cannot find that error number in my searches.
Any ideas?
(3,117 Views)
What steps of debugging/solving did you perform up till now?
Does the error occur as soon as you try to access the device or only when performing a specific operation?
Afaik, the USB 6001 is an OEM product (read: unboxed). How is it mounted? Have you visually checked the device for damage?
Norbert
Norbert
Expert: Geometry
(3,083 Views)
Thanks Norbert_B.  Food for thought.
Unfortunately the setup is 200km away.  I found instructions to test the machine in NI MAX and passed them on the the user. They have two USB-6001 and can do machine swapping etc.
I suspect hardware malfunction owing to condensation etc.  Just hard to see how it can turn up as an unknown error in sofware.
OurUSB-6001s came from NI already packaged.
(3,070 Views)
