Error -2147024894 when trying to use ActiveX Automation Open
I use the Automation Open on an ActiveX Class (which is creatable when I choose it from the list). When I do this I get the error:
Error -2147024894 occurred at The system cannot find the file specified.
Does anyone know what this error means?
Thanks a lot,
Laurent
(8,625 Views)
OK, I reinstalled the software I want to control via the ActiveX controls, and I now get another error message:
Error -2147312566 occurred at Error loading type library/DLL.
It seems that it cannot find the DLL. How can I solve this?
(8,622 Views)
Hi Laurent,
This is usally caused by registration problems of your activeX server with Windows. This is usally done while you install a ActiveX capable application but it could fail. for more information see the attached Knowledge base. This deals with LabWindows/CVI and MS Excel but this is more a general issue.
Hope this helps
Karsten
(8,614 Views)
Thank you, it works now. I had to change some registry entries which pointed to a wrong folder.
Laurent
(8,609 Views)
