Error -20080 quadratic programming
hi,
 I tried to to the qp vi that is present in mathematics/optimization toolkit in LV8. The same inputs (matrices) are given to matlab script node and quadprog command is used. It is running fine.  I tried qp vi and gave the inputs accordingly. It is showing
Error -20080
 Time increment must be greater than the (window length)/16
please help I m not getting what the error is.
I want to download this vi into fieldpoint. As it not allowing to download the script node i must use qp vi.
Message 1 of 15
(3,601 Views)
There are several robust QP solvers in TOMVIEW that you can try out - QPOPT, CPLEX ans so on. http://tomopt.com/tomview/
Best wishes, Marcus
Marcus M. Edvall
Tomlab Optimization Inc.
855 Beech St #121
San Diego, CA 92101-2886
USA
web: http://tomopt.com
e-mail: medREMvall@tomREMopt.coREMm
Office1: (619) 203-2037
Office2: (619) 595-0472
Fax: (619) 245-2476
Message 2 of 15
(3,581 Views)
I want to know why iam getting that error?. how to get rid of that error using that vi?
Message Edited by sainath on 02-23-2007 02:16 AM
Message 3 of 15
(3,571 Views)
I am not familiar with the mathematics and optimization toolkit in LabVIEW.  Here is the list of toolkits that NI provides:
http://www.ni.com/labview/family.htm
Any of these that you are talking about?
Nadim
Applications Engineering
Message 4 of 15
(3,551 Views)
May be a problem finding an initial feasible solution.  Can you post the code that is giving you problem so that we can take a look?
-Jim
Message 5 of 15
(3,542 Views)
Hi Jim,
       I have attached my program
-sai
Message Edited by sainath on 02-26-2007 02:20 AM
Message 6 of 15
(3,535 Views)
Had some problems with some missing subVIs.  Can you create a quick wrapper for the QP call and save with the default data that reproduces your error?  In other words, highlight the qp VI, and from the edit menu choose create subVI.  This will create a simple wrapper.  Open the wrapper VI, and then run your application until you see the error.  Now go to the wrapper and from the edit menu choose make current values default, and then save the VI.  That should be sufficient for me to reproduce the error without needing your subVIs.
-Jim
Message 7 of 15
(3,523 Views)
Sai:
As Jim mentionned, it will be easier for us to help you if you could isolate the problem. Please let us know if there is anything else we can help you with throughout the process.
Rudi N.
Message 8 of 15
(3,515 Views)
Hi jim and Rudi,
        sorry for the delay. This time i have attached the wrapper file with the default data that was giving me the error. (Actually with QP vi it is not running even for one iteration.)
Message 9 of 15
(3,486 Views)
Sai,
The problem is in the mapping you have made from "quadprog" to Quadratic Programming.vi.  You are passing your inequality constraints into Quadratic Programming.vi as equality constraints.  For this set of constraints (as equality constraints) there is no feasible solution.  Simple inspection of the constraints shows this.  Quadratic Programming.vi requires that the inequality constraints have both an upper and a lower bound (InEqu_lowBound <= Dx <= InEqu_uppBound), but you can use +/-Inf in the bounds arrays.  Attached is a modified version of the warpper that shows the mapping.
-Jim
Message 10 of 15
(3,475 Views)
