Error -200220 occurred at DAQmx Create Channel (AI-Voltage-Basic).vi:1780002
Hi. I am testing my NI MyDAQ for the EMG monitor I downloaded from this community. And the error stated above occurs. What is the solution in this problem? Thank you.
Message 1 of 10
(4,405 Views)
The Device Identifier is invalid.  If we saw the code (attach a VI, not a picture, please), we might be able to tell you how to fix this ...
Message 2 of 10
(4,372 Views)
Hello. This is the VI that I have downloaded in this site, also there are no .png images attached on the zip file. Can you also help me with that? Thank you
Message 3 of 10
(4,354 Views)
Hi nerudorin,
there is no VI, no PNG and no ZIP (and not even a link)!
Message 4 of 10
(4,352 Views)
Hi. I'm sorry, https://decibel.ni.com/content/docs/DOC-25987#comment-51398 this is the link for the myEMG monitor I am trying to modify. I uploaded the VI but seems it wasn't. Try to go on the link so you can try the emg monitor and can identify the problem. Thanks, Godbless.
Message 5 of 10
(4,347 Views)
Hi nerudorin,
unfortunately I don't have the needed BiomedicalToolkit installed, so I cannot check the settings in all those ExpressVIs and missing functions…
From plot names I guess the original author had a device named "myDAQ1" - do you use the same?
Message 6 of 10
(4,344 Views)
I suspect that GerdW (and I) has identified the problem you are having.  You use an Express VI to take the data from your MyDAQ.  It wants to "talk to" a specific named device, and if it doesn't "see" a device by that name, it will throw the Error you encountered.
  • Is your MyDAQ plugged into your PC via its USB cable?
  • If you open MAX, can MAX "see" your MyDAQ?
  • Note the name that MAX gives to your MyDAQ.  You need to use the same name to connect to that MyDAQ with your ExpressVI.  Do you know how to check and make sure that is the case?  Alternatively, you can use MAX to reassign the name it gives your connected MyDAQ so that it matches the name the Express VI wants to see.
Message 7 of 10
(4,334 Views)
Thank you for all your help, I'll try to do your suggested solutions. I'll keep you posted.
Message 8 of 10
(4,316 Views)
Message 9 of 10
(3,945 Views)
Okay.  So you have the same error message as described in this message thread you posted into.  Do any of the previous messages help?  If not, then give some useful information with your message.
Message 10 of 10
(3,940 Views)
