NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
Jack_W
Error 200088 when measuring Voltage
I am trying to measure multiple voltages at the same time, with a finite number of samples. This should run in a for-loop, with different settings for other voltage outputs. However, I am getting an error 200088 at apparently random points of time.  Most iterations of the inner for loop run fine, but around once every 20 times, error 200088 occurs.
Also, at other points I get an Error -200429.
Thanks for any help.
Cheers
Active Participant
ShotSimon
Re: Error 200088 when measuring Voltage
Member
Jack_W
Thanks, I read this article before.
Therefore, I tried calling another VI e.g. the "Is task done"-VI before calling the timing VI. This didn't solve the problem. Also, this issue occured in Labview7, and was supposed to be resolved for later versions.
So should the code work fine?
I actully just want to run the voltage measurement in the inner for loop multiple times with the different array-elements that are sent to the loop. So I thought the best way to "fix" the problem is to create the task within the loop and clear it when exiting the loop. However, the problem is as described...
:smileyindifferent:
Member
Jack_W
Here is a stripped down version of my VI.
Member
GregorP
can you give some more information about your Hard- and Software?
Which LabVIEW version do you use?
Which DAQ Version do you use?
Which DAQ Parts do you use?
Which operating System do you use?
Best regards
Member
Jack_W
I  had the problem using Labview8 with Windows XP.
As shown in the VI above, I use
Create Task
Create Channel
Timing
Read
Wait Until Done
Is Task Done
Clear Task.
Hardware is a USB 6211.
I hope that helps, thanks!
Member
GregorP
there is an existing bug report for exact same Error occurance (-200088 and -200429). This problem was discovered during the developement of LabVIEW 2009 and fixed immedeatly. Since you are using LabVIEW8 and i could't reproduce the errors with Labview 2011, the only solution i see is, to upgrade your LabVIEW Version.
Best Regards
Gregor
Member
Jack_W
Thanks for that! I "feared" that. the trouble is, is run a more or less self-programmed stepper motor in the program. I can only get this to run using Labview 8. Well, I guess there is no way around the upgrade now.
Thank you.
Member
GregorP
You're welcome.
Why is it only possible in LabVIEW8 ? What is the limitation?
Member
Jack_W
My program code also runs fine on Labview2010 (on another machine)- I will test the long term measurement tomorrow - hopefully the error is solved in the 2010-Version.
The reason I don't want to upgrade on those lab-notebooks is that colleagues are running hardware that was programmed for LV8. In the past, upgrades cased lots of trouble with driver etc. However, I will try the upgrade although that would mean solving many bugs in programs I didn't write when I have the time for all the troubleshooting.
I will comment on how the whole thing worked under 2012
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
