04-24-2017 07:52 PM - edited 04-24-2017 08:08 PM
This seems like a Microsoft vs LabVIEW compatibility error. Trying to build an application I receive "Error 1502 occurred at AB_Source_VI.lvclass: Close_Reference.vi->AB_Build.lvclass: Save.vi". The broken vi is located: C:\Program Files (x86)\National Instruments\LabVIEW 2016\vi.lib\addons\_office\excel.llb\Excel Add Reference to VBproj.vi. I hesitate to send out another service request as I do not wish to re-install LabVIEW or "make the program again". The second image is the same as the first except the tip strip is visible in the second. I am unable to right click and "relink" in the same manner that worked the last time there was an ActiveX change/issue/thing. I await some condescending responses and hopefully a good suggestion. Thanks.
Solved! Go to Solution.
04-25-2017 12:54 PM
A colleague was able to perform an application build with the source code on his machine. I replaced the _office folder with a copy of his and I am now able to compile again.
05-09-2017 12:33 PM
I encountered the problem again. The application builder broke the vbproj.vi. I opened my control panel and performed the quick repair on Office 365. It took about 30 seconds to repair. When I opened the vi again it was miraculously fixed. I guess an office file went missing, no idea why, I feel LabVIEW is responsible. I am now able to build the application again.
11-27-2017 09:52 AM
"I opened my control panel and performed the quick repair on Office 365."
Could someone precise how to do this, please? I also have the same problem after installing Office 2016 (365).
Thanks!
11-27-2017 10:43 AM
Lasting Fix:
1. Open the NI_ReportGenerationToolkit.lvlib:Excel_Save_Workbook.vi
2. LabVIEW then recompiles the VI for whatever version of LabVIEW is being used. So when we try to exit the VI we get this:
3. It is at this stage that we get the broken arrow:
4. At this point we can right click on the invoke node and relink it to the active X library it's calling which results in an extra field:
5. After this the VI works without issue.
If we fail to relink the invoke node, the VI will save in a broken state and become unusable until someone relinks the invoke node.
NI has been sent the fix.
Good Luck!
11-28-2017 08:21 AM
Thanks hefengloven,
I made the correction, but stiil have the same problem you had on 04-24-2017 post, where _Workbook>VBProject output was a Variant instead of an Automation reference of class in NI_Excel.lvclass:Excel Add Reference to VBProj.vi.
Would I be missing something?
