06-10-2015 02:53 AM
Hello
I am new to Labview and object oriented programming. I have an already written c# code which communicates with a digital I/O card attached to a test system. I want to run those c# functions in labview. I am using .NET constructor pallett and then invoke node but I am receiving following Error:
Error 1172 occurred at Invoke Node Error calling method DmmCSharp.Handler.Reset, (System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation.
Inner Exception: System.Runtime.InteropServices.COMException: KtMDsr: A connection to the instrument has not been established.)
Image file of error and vi file is attached below.
06-10-2015 04:35 AM
The clue is in the 'A connection to the device has not been established'. You are trying to reset the device - presumably without having first configured the appropriate parameters or opened connection to it so the library is probably throwing that error.
