Error:1127.Cannot instantiate template VI because it is already in memory.
Hi All,
I ran in to a problem while developing an Application. I am a fan of .vit files, I use to create a template .vit file and instantiate the front panels of different kind during run time.
So far I have never came across the error 1127 Cannot instantiate template VI because it is already in memory. The application runs fine in Development system, but if I build that to a .dll and call template I got the above error.
This .vit instantiated objects are front panels which resides in a sub panel of the main vi.
I saw the other posts but i didn't came across any useful solution.
Thank you
Aptan.
(2,638 Views)
Why are you using VITs? Using .vit files for launching multiple instances of a VI/running VIs dynamically is no longer the recommended method - you should look at using the 'start asynchronous call' method instead.
http://zone.ni.com/reference/en-XX/help/371361H-01/lvhowto/acbr_call_and_forget/
(blog)
(2,622 Views)
