Error 1082 when setting Strings[] property of a menu ring control via property node.
I've attached a VI in which I attempt to set the Strings[] property of a menu ring control via a property node.  Can anybody figure out what I'm doing wrong here?  I'm using LabView version 7.1.
Mark Moss
(2,791 Views)
Open up your Stations Parameters Control.ctl file and change it from a Strict Type Def. to just an ordinary Type Def. (the pull down menu is located next to the font selector).
(2,786 Views)
That seems to have been the problem.  Thanks.
(2,778 Views)
