08-17-2014 03:23 PM
I am new to labview.
I got the following error when I tried to read measurements from "Mark-10 Force guage-Model M4" using labview.
Error -1073807246 occurred at Property Node (arg 1) in force guage.vi:Instance:2->force guage.vi
Possible reason(s):
VISA: (Hex 0xBFFF0072) The resource is valid, but VISA cannot currently access it.
I have tried many things that have been posted in the forum including reinstall Visa but nothing work.
I am able to read the data from inside Instrument assistant but can not pull the data out of it.
please see the attachment.
I appreciate any help
Thanks in advance
08-17-2014 03:30 PM
08-17-2014 03:36 PM
I didn't run lab view at the same time with interactive control or Max. the reason I show a snapshot from Visa interactive is to show that Visa interactive recognise the devise.
08-17-2014 03:41 PM
08-17-2014 06:11 PM
Figured out after reading an old post for you.
It was all about the terminatio
It is working now after I used the advanced example and changed the termination charecter.
Your old post:
http://forums.ni.com/t5/LabVIEW/Changing-termination-character-doesn-t-seem-to-work/td-p/1898241
08-17-2014 06:30 PM
08-18-2014 01:51 PM
Actually, the program that I wrote using instrument assistant didn't work.
When I used the advanced example I couldn't read any data at the begining but it workeed after changing the termination charecter.
So, it might be something wrong with the instrument assistant in addition to the termination charecter thing.
