03-24-2015 10:11 AM
Hello, I'm working with a statechart module in LabVIEW, there is a program made by other persone and I have to know how it works. I made a little change and when I want to generate the code I have a error 1000. I want to know why.
Hope you can help me. Thank you
03-24-2015 11:00 AM
This is an unusual error. It suggests that something might be open or perhaps running when you are trying to generate your statechart code.
When I generate new statechart code, I usually do so from a freshly opened LabVIEW project so that I know nothing is running and ONLY the statechart code is open.
If that doesn't work for you, I'd suggest posting your code if possible.
03-24-2015 11:18 AM
Thank you for the answer. I do that, there is just the statechart opened but it don't work. I don't know how it works exactly, I'm new in this.
03-24-2015 01:33 PM
Unfortunately none of your VIs were attached with your statechart code, so I can't really see what's wrong.
If you can attach the 5 missing VIs, I should be able to quickly try making a change and rebuilding the statechart to see if I get the same errors.
Which version of LabVIEW are you using?
03-25-2015 10:32 AM
I think that it is a problem with my program because I did it in another computer and it worked. Thank you very much.
