06-26-2013 11:40 AM
I have started getting this error in LabVIEW even though I have plenty of RAM available.
LV is using about 900MB with over 1GB free and I can't save a 4.9MB VI (It contains several FPGA Bitfiles, that's why it's so large).
The error window tells me "Default data space" as a description and the only link I can find has to do with variant changes between 8.21 and 8.5. I'm using LV 2012 SP1.
Anybody know what's going on? Is this even the right error message?
Shane.
06-27-2013 04:17 AM
are you getting... ""LabVIEW: Memory is full" ?
If you open the VI after just restarting LabVIEW, could you run the VI without any memory error?
06-27-2013 08:55 AM
Yeah, it accompanies a "Memory full" error.
Restarting LV (And losing any recent changes because I couldn't even save the VI) worked fine.
06-27-2013 09:13 AM
I think, this memory error is expected. This as not a bug.
I'm not sure. maybe this is caused by a corruption in the project file and not in the actual VIs contained within it.
what to try is to create a new project and move the contents from the old project over to the new.
I hope this helps you
06-27-2013 09:20 AM
This is triggering a memory, a distant memory. Something about "default data" in a VI, and when that default data reaches a particular size it can cause issues. Something to do with a few people experiencing corruption in their VIs due to the default data being a particular total size, and that one solution (from memory) was to increase the default data size to surpass a particular limit which caused something to change in the saving of the VI. That's all I can recall though, which isn't very helpful - sorry!
06-27-2013 09:24 AM
Well if it's not a bug (Which I never claimed BTW) I would very much like to know where the error comes from and what the "Default Data Space" refers to.
I am not aware that my VI had such a large memory footprint. It was actually a quite small VI, and EVERY VI was affected after the error occurred. I couldn't save ANYTHING.
Needless to say, I'd like to avoid this error in future.
I won't be trying the project move idea because our project has multiple targets in it and would take considerable time to duplicate.
Shane
