Error 1 when building my application in Labview 2010 Version 10.0f2
LV 2010 SP1 took care of what ever issue I was having..
Message 11 of 16
(1,247 Views)
Hello RRRRSSSS
Glad to hear it!
Sincerely,
Greg S.
Message 12 of 16
(1,243 Views)
I just got this exact same problem today. One minute I  was building executables perfectly fine, with no errors (LV 2010 SP1), and the next it wouldn't build any project, old or new, giving the same Error 1.
I did a LabView repair and it resolved the issue.  Just an FYI for anyone else searching for an answer
Message 13 of 16
(1,209 Views)
I solved the problem by creating my own waveform generation vi and removing the NI Sine Waveform.vi from my project.
Message 14 of 16
(1,201 Views)
This is not resolved, even in LV 2011. Below is the error I get. I am going to try all the suggestions that Greg S has recommended. But, NI has to resolve this instead of suggesting workarounds.
Error:
Visit the Request Support page at ni.com/ask to learn more about resolving this problem. Use the following information as a reference:
Error 1 occurred at AB_Application.lvclass:Create_INI_File.vi -> AB_Application.lvclass:Copy_Files.vi -> AB_EXE.lvclass:Copy_Files.vi -> AB_Build.lvclass:Build.vi -> AB_Application.lvclass:Build.vi -> AB_EXE.lvclass:Build.vi -> AB_Build.lvclass:Build_from_Wizard.vi -> AB_UI_Frmwk_Build.lvclass:Build.vi -> AB_UI_FRAMEWORK.vi -> AB_CreateNewWizard_Invoke_CORE.vi -> EBUIP_CreateNewWizard_Invoke.vi -> EBUIP_CreateNewWizard_Invoke.vi.ProxyCaller
Possible reason(s):
LabVIEW:  An input parameter is invalid. For example if the input is a path, the path might contain a character not allowed by the OS such as ? or @.
NI-488:  Command requires GPIB Controller to be Controller-In-Charge.
Message 15 of 16
(1,153 Views)
This issue is even not resolved in LV 2011 SP1 f2
I also had error 1 thrown at AB_Application.lvclass:Create_INI_File.vi
More details in this message
Message 16 of 16
(1,059 Views)
