05-21-2014 08:41 AM - edited 05-21-2014 08:42 AM
Well, don't take it personally but debugging with a middle person is very cumbersome and unlikely to get you anywhere fast.
Basically error 1 means that an argument to that property node is invalid. Most likely it is the object reference on which that property wants to operate on. Which property node that is is impossible to determine from the error message, for that one needs to be able to look at the LabVIEW diagram of the VI in question. Next cause of action is to determine why that property node receives an invalid reference.
All these things can only be done by someone with access to the LabVIEW source code and who understands LabVIEW program to a decent level. Without any LabVIEW programming knowledge you could just as well look at the electrical wiring schematics of your building and conclude about as much.
So to conclude this, the error means something went wrong in a way that the programmer did not expect to happen, and that programmer did not do an optimal job in handling errors in his application in such a way that the location is more easily found out. Also it most likely is a real programming error that should be fixed in the LabVIEW diagram of that VI. A race condition as already mentioned earlier is a quite likely possibility such as that the property node tries to access a property from an object that hasn't been created yet. This happens quite often if a not so professional LabVIEW programmer wires together a program without understanding and using proper LabVIEW dataflow.
05-21-2014 12:10 PM - edited 05-21-2014 12:11 PM
Thank you.
