09-11-2006 05:27 AM
Lorne,
I'm using the following hard and software:
PCI 1424 (checks out fine in selftest)
Redlake ES4 12 bit (selected in NI MAX)
NI IMAQ 3.5.1 (I noticed it does not pop up in a window like it does when starting up other software, can this be a problem?)
Cable 185275 B 04 (instead of 185275 B 02, can this still be an issue?)
I still get the 0xBFF6001F error.
The camera works with cable 810028-145-03 on an older computer with other software, when I use cable 185275 with that configuration I get the missing bits again I had in the beginning on the new computer. So the other cable might help to get a good picture as soon as I get beyond the error.
Harry,
09-12-2006 10:27 AM
09-13-2006 01:21 AM
Hi DJ,
I got it all working now. It appeared that the Redlake camera was modified in the past, and needed the Roper ES4 file instead of the Redlake file.
You can't imagine how relieved I am to get it finally working!
Thank you very much!
09-13-2006 06:47 PM
02-05-2009 04:25 PM
Hi sir,
I have a very similar problem.
I have several PCI 1407 cards.For the same camera,I can get an image from Measurement and Automation from another card.
But I can not get anything by this card.I tried to use "self test" function, it said that everything passed.I am woundering if this PCI 1407 is broken,but is there any way that I can make sure that this is the problem for this card?
Thank you
02-13-2009 03:43 PM
Hi Chin,
What camera are you using? What driver are you using?
What happens when you try the suggestions listed on the sixth thread here on page one? what about the second thread on this page?
There is a small chance that the card is damaged but it is not likely because the self test passed.
05-12-2010 04:10 PM
I'm also getting that error.
I'm running the following.
Basler A403(k)
PCIe-1429
IMAQ 4.1.0
Any ideas?
Ricardi
08-17-2010 05:51 AM
hi, I am also getting the same error
I am using a Xenics Camera and the framegrabber is NI PCIe 1429. I am stuck up with my work because of this error. Please help.
Anirudh
09-15-2010 04:42 PM
05-09-2015 07:47 AM
Hello all,
I am using HiSense MkII CDC camera and geting he same error.What can i do?
