02-17-2006 11:30 AM
02-20-2006 05:28 PM
02-21-2006 02:31 PM
how do I select the proper camera type?I tried snapping a picture from measurement & automation explorer,but it does not work.
This is what ,I see in measurement & automation explorer;
devices & interfaces
NI IMAQ devices
img0 ni pci 1407
channel 0 : 25 Hz progeressive scan
and in the software
Ni imaq 3.5.1 ( I think it is the latest one)
ni imaq for 1394 2.0.2
Thanks a lot !
Deepak
! Do I need to install any other sofware apart from imaq driver?
02-22-2006 06:20 PM
02-22-2006 06:20 PM
02-22-2006 06:25 PM
Deepak,
You can change your camera type by opening up Measurement Automation Explorer (MAX) and expanding the item tree to...
Devices and Interfaces->NI-IMAQ Devices->Img0 : PCI-1407->Channel 0:25 Hz Progressive Scan
Right click "Channel 0: 25 Hz Progressive Scan" and goto...
Camera->Standard->(then select the right camera protocol type).
If you are not sure what type of protocol your camera uses, you can usually find out by looking at the camera's datasheet.
If you already have the right type selected, you might be having other issues. You camera could be damaged, unplugged, not powered on, your 1407 might be damaged.
If this does not solve your problem, please let me know.
Lorne Hengst
Application Engineer
02-23-2006 02:58 PM
Hi Lorne
Thanks a lot !
I just changed the camera setting and it worked.
Thanks again!
Deepak
09-07-2006 01:59 AM
Hi!
I'm having the similar problem with a Redlake ES4 camera.
I sometimes get the 0xBFF6001F error, while I have the right camera selected (Redlake ES4 12 bit). The PCI framegrabber checkes out OK in the selftest, and is new.
The camera works fine with other software at another machine.
A few times I did get a picture, but it appeared like some of the bits are gone, the picture has very little contrast.
I hope somebody more experianced than I can help me out?
09-08-2006 09:44 AM
Harry,
I am guessing you are using the PCI-1424, is that correct?
Also make sure you are doing the following...
"PCI-1424
Known support limitations:
In continuous mode, the minimum settable exposure time is 1ms.
This camera file will only work with NI-IMAQ 2.5 or higher and will only work with cable p/n 185275B-02 from National Instruments."
http://sine.ni.com/apps/we/nipc.product?pid=2223
Lorne Hengst
09-11-2006 01:51 AM
