09-03-2014 06:34 AM
Hi
am using NI USB 6009 daQ.using labview signal express to calculate the curent using 10 ohms shunt resistor. i can obtain the voltagedrop vs time plot.
How to obtain the energy vs time plot by integration. Is there any vi to convert the voltage or current values to energy ?? if so please explain.
Thankyou
09-03-2014 06:39 AM
P = I*V. So since you have the voltage and current, you just multiply those to get your power. Then to get the energy, just use Integrate on the power curve.
I haven't used Signal Express, so I don't know if that is possible with that software. The tools are definately there in LabVIEW.
