07-05-2006 12:51 PM
07-05-2006 03:53 PM
07-05-2006 04:19 PM
07-06-2006 08:13 AM
07-06-2006 10:33 AM - edited 07-06-2006 10:33 AM
Message Edited by Jarrod S. on 07-06-2006 10:36 AM
07-06-2006 10:42 AM
07-06-2006 02:54 PM
Hi Jarrod,
Thanks for the help! You're right, I dont get that Error 4 message anymore!
I have some more questions. When I save the measurements to a file on my VI, my vi then outputs what I saved on the spectrum analyzer. But when i save it again, the display doesn't change at all. I know that there are noticeable miniscule changes on the spectrum analyzer as it runs in real time, but the display on my VI doesn't change at all. Also, when I open the destination file that I saved the plot to (after clicking "save" numerous times when the vi was running to double check if the display changed at all), I get a long list of measurements and apparently, everytime i click save, the measurements were appended to the end of the file. This is weird because I already told the "Write to Measurement File.vi" to overwrite file if a file name already exists. There isn't any append to file setting for "Read from Measurement File.vi." Do you know what could be wrong?
Also, the display from the saved file seems like it's been offsetted to the right compared to the display of that from the "dump" function. Could it be possible that the "Write to Measurement File.vi" starts the x-axis from 0? I've included a picture of this occurrence and my vi.
Thanks Jarrod for the help!
- Sammy
07-06-2006 03:06 PM
07-07-2006 12:01 PM
Hi Lynn,
I don't see the reset parameter on the Read Measurement vi. Do you mean overwrite samples parameter?
Sammy
07-07-2006 12:07 PM
Hi Lynn,
Nevermind! I know what you mean now. Haha..Thanks!! The display from the file is changing everytime I press save now. Although the offset still occurs. I'm not sure what's happening there. Could you help me out on that issue too?
Thank you so much,
Sammy
