07-16-2016 08:57 PM
When I call the Elapsed Time function, the "Present (s)" output according to Help: "Displays the present time in seconds since 12:00 a.m., Friday, January 1, 1904, Universal Time [01-01-1904 00:00:00]."
My output is always the same number when Start Time set to 0 (which should set the start time to "Now". I'm missing something but don't see it.
07-16-2016 09:35 PM
It just appears to stay the same due to the Display Format of your indicator. Change the Display Format to 10 digits of precision and you will see what I mean. Another option is to use the To Time Stamp and make an indicator for the time stamp.
07-16-2016 10:36 PM
I gave up on using that Express VI and went to Millisecond Timer. In my case it's easier to use as long as you take rollover into consideration.
