Efficiently remove then append chunk of 2D array
I have an array that is 72 rows (32 channels, 8 channels, 32 channels). I am trying to take the middle 8 channels and move to the end so it will be 32, 32, 8. I could delete a subset from the array then append to the end but I think that would cause 2 allocations. Was wondering if there was a more clean, inplace way of doing this?
(2,106 Views)
Accepted by topic author GregFreeman
Take 2 array subsets (32,8) (40,24) and then do two replacements into the original array (indices 64 and 32).  I find it is typically twice as fast as delete + rebuild (cleanest looking), which is twice as fast as the IPES (slowest and ugliest by far). Your mileage may vary.  It is all microseconds at that array size.
(2,096 Views)
Thanks Darin. Yes, it wasn't so much a matter of efficiency in this case, but general best practice.
(2,063 Views)
